AutoLeveling Bed / Tramming
Postby JohnnyBoy » 27 Dec 2014, 08:27
The process of getting RigidBot working with Autobed Leveling has alot of problems before its working. When its done its worth all the work :D
First you must begin with a working Firmware (FW) for the Rigidbot(RB) and all the sourcecode. I have attached a version of the RigidBot Community Edition (RBCE) sourcecode . The original and updates can be found at http://rigidtalk.com/viewtopic.php?f=3&t=201
The guide (will be) is attached as a step-by-step guide. (In working progress)
Guide for Auto Bed Level.docx
(1.1 MiB) Downloaded 371 times
Firmware RBCE.zip
(2.99 MiB) Downloaded 234 times
JohnnyBoy
Re: AutoLeveling Bed / Tramming
Postby epatel » 03 Apr 2015, 12:26
Hi,
I have added an alternative bed levelling (compensation) feature to Marlin. I bought a "started" RigidBot BIG kit, which was pretty bad and I had major problems getting it working. So I added a new bed levelling feature in Marlin just to get it working. It has now been merged and is available in the current Marlin. My setup is also maybe a little different but I think this feature is really good for large build plates.
You can read about it here
https://github.com/MarlinFirmware/Marlin/pull/1619
To use read here
https://github.com/MarlinFirmware/Marli ... eveling.md
epatel
