Windows not going up or down.
Postby williamhawk » 20 Sep 2017, 13:40
Hello been awhile everybody. Well just recently my windows will not go up or down. I dd some research and, disconnected the battery didn't work, I checked all fuses and relays all good, and checked the wire harness looks brand new.
I decided to buy a new switch, even with a buddy of mines discount it cost a pretty penny, and that didn't work either. After researching some more I saw possibility of it being a door module. So my friend said bring it to the dealer he works to check it out.
After they ran everything, no codes. Double checked everything I've checked nothing was wrong, and on top of that they said there is no door module in my year Journey. They would have to keep it a day and follow the wires and possible pcm problem.
References http://www.dodgejourneyforum.com/topic/ ... p-or-down/
Installation video
williamhawk
Re: Windows not going up or down.
Postby Stellamaxwell » 21 Aug 2018, 06:45
A page file is a portion of your hard drive that is set aside by windows to act as an overflow if your system memory or RAM isn't enough. Whenever you access the page file it will be a lot slower than your RAM genuine coursework writing service. RAM is purpose-built to be used like this and a hard drive just can't reach the same speeds.
Stellamaxwell
