Problem Accessing to my User
Postby jackneeson » 17 Jul 2018, 10:50
Hello,
I have a problem; my machine is working with an external display (Screen) since the one that came with the laptop does no longer works. Today I moved the resolution of the display and I cannot access to my main user; the only way to access the computer is through invited user but there I cannot install programs or do anything. I tried to reinstall linux but since the laptop is useless I cannot access to the BIOS. I am trying to create another user but since I am in the invitation user, I cannot make any changes to the system. Is there a way I can add permissions to the invitation user so I can delete the main user and start using this one instead? what other ideas do you have that might solve my problem? I tried also to access to move the resolution in my main user but that did not work either.
Any help will be apprecited.
References:
https://forums.linuxmint.com/viewtopic.php?t=271147
Web Video Animation Agency
Thank you.
jackneeson
Re: Problem Accessing to my User
Postby michy5 » 05 Aug 2018, 14:36
I've had also such issue but then it gone itself.
http://rooftopsnipersgame.com
A smart man only believes half of what he hears, a wise man knows which half.
michy5
Postby arianapham » 17 Jan 2019, 06:38
Thank for your writting! It is easy to understand and detailed. I feel it is interesting, I hope you continue to have such good posts Cat Mario
arianapham
