by AndreyM » 19 Aug 2014, 00:53
After putting in the replacement e-bay thermistor, I have a weird problem of having to reload filament into the extruder after every print. Lets say I have a successful print, then load another file and start printing. However, the head would move, but no plastic is extruded. I have to pull it out, cut off the end, and manually push some through. After this step, the print would work. Did I just not quite tightened the screws together on the extruder or might there be another problem? Thank you
