Having to manually push through filament after every print
Postby AndreyM » 19 Aug 2014, 00:53
After putting in the replacement e-bay thermistor, I have a weird problem of having to reload filament into the extruder after every print. Lets say I have a successful print, then load another file and start printing. However, the head would move, but no plastic is extruded. I have to pull it out, cut off the end, and manually push some through. After this step, the print would work. Did I just not quite tightened the screws together on the extruder or might there be another problem? Thank you
AndreyM
Re: Having to manually push through filament after every pri
Postby spiderdaddy » 19 Aug 2014, 14:23
After a print try setting the temperature manually and then extruding 20 cm. This should work without problems.
For instance:
M104 S190
Then
G91
G1 E5 F300
G90
Or use Pronterface or Octoprint controls.
Postby mavgrab302 » 26 Aug 2014, 19:35
the sure way to keep this from happening is to just before you start your print feed the line in till it bottoms, then lift up a few mm...directly after your print push the lever and take out filament...takes about 2 seconds to do it and well if it isn't there it won't get clogged..I've had other issues but i'm usually close by when it stops so thats the only catch..
