Bad part replacement
Postby hapoo » 26 Jul 2014, 18:17
I received my rigidbot several days ago, ripped open the box and started assembling it. Unfortunately for whatever reason I'm missing screw 1108 and part 1068 doesn't fit the motor shaft. I sent an email to inventapart and still haven't gotten a response. Anyone know where I can get some replacements?
hapoo
Re: Bad part replacement
Postby spiderdaddy » 26 Jul 2014, 20:27
I can't give you specific replacements, but there are several suppliers mentioned in the unofficial Parts List here: http://rigidtalk.com/wiki/index.php?tit ... Parts_List
These are of course user group recommendations and YMMV.
Hope this helps.
BTW, better to use https://iap.supportsystem.com/ than e-mail. That way you get a tracking number and can follow up.
Postby hapoo » 27 Jul 2014, 16:34
Just what i was looking for, thanks for the link to the support page spiderdaddy.
hapoo
Postby bobhinkle » 13 Aug 2014, 23:42
Just a heads up on the screws. If they take too long i went to my local hardware store and found all the screws i need to complete my extruder. They are m3 x .50 x (needed length). Cost me about $2 for all the extruder srews that i didn't have.
bobhinkle
Postby Klantz » 14 Aug 2014, 03:02
Another source on M3's is a hobby shop. My local hardware stores had nothing, but HobbyTown had every length M3 I could ever want.
Klantz
Postby ramak » 15 Aug 2014, 20:24
The extruder gear is a common problem and usually an easy fix. See this wiki page: http://rigidtalk.com/wiki/index.php?tit ... otor_Shaft
ramak
Postby Snarkticon » 17 Aug 2014, 15:29
I was assembling my kit last night and found I was missing the same screw (1108) as well as the 1109s and 1110 for the extruder. Thanks for linking to the parts list on the wiki, spiderdaddy - it's a lot more detailed than the set that came with the kit.
FYI - Home Depot is zero help. I was able to find the 1108 screw at a local mom-n-pop hardware store, but nothing matching the 1109 or 1110 screws.
"Somehow there's always someone who can do things thought impossible, simply because they do not realize that they should be incapable of the achievement." - Achievements In Ignorance, TVTropes.org
Snarkticon
