Under extruded upper layers?
Postby DrMerlin » 25 Sep 2014, 17:05
I just completed my first major print- 7 inches tall and about 300 grams. I used Cura. It's white 1.75mm PLA at .2mm layer height and took about 20 hours.
I don't know if you can tell from the photo, but the bottom layers are completely fused, and about 3 inches up it starts to get less and less fused as it gets higher.
The measured height is almost exactly what Cura said it would be- so I think the Z-calibration isn't the problem nor is z-axis movement.
Any thoughts on what would cause issues as the model got taller?
DrMerlin
Re: Under extruded upper layers?
Postby spiderdaddy » 28 Sep 2014, 22:39
You can't really see that from the pic, can you post some close-ups of bottom and top.
This might be worth a read.
http://reprap.org/wiki/Print_Troublesho ... emperature
Postby DrMerlin » 09 Oct 2014, 15:58
Hey- thanks for replying- I missed it somehow.
http://www.soliforum.com/topic/4947/hel ... gh-prints/
This page is basically what I was seeing- except it would come and go. But I cleaned out the hotend and it instantly got a lot better.
DrMerlin
