Question On Morningstar Solar Controller Output To Battery
Postby MichaelSmith » 19 May 2018, 03:41
Finally got a solar panel (95 watt) and rigged a power wire with the 3-wire male solar plug supplied with the CI 550 Ultra. Put the panel out in the sun and plugged it in. The meter read 17.1 volts and 4.47 amps. This seemed like straight uncontrolled solar panel output. I was worried that the high voltage would cook my AGM battery so unhooked the panel right away.
According to the data sheet, the solar controller should be putting out something around 14.1 volts. What volt readings are typical when the Morningstar SunSaver SS-10-12V is charging from a solar panel?
Any help will be apprecited.
http://campinnforum.com/community/threa ... tery.4385/
Best video production service
MichaelSmith
