mechanical issue
mechanical issue
Postby williamhawk » 13 Oct 2017, 08:18
I got a new problem. 2.2 4WD crdi 2006 santa fe. let me try to explain it. when I turn on the left and sometimes to the right also, it makes a noise like a bad CV joint?. but it already has two new outer cv joints, and the inner ones are ok (checked by a specialist). the problem is not only the noise, when you try to make a u-turn to the left, or when trying to turn at maximum to the left, the wheel locks a little and feels it's about to break or something like that..a mechanic told me I should change the transmission oil ¿¿?? but this does not make sense to me, any ideas?
Please help.
Thanks!
References http://www.hyundai-forums.com/santa-fe- ... issue.html
Brand Reveal
williamhawk
