Just got my 10x10 assembled and calibrated. No lcd
Per original post...
I have the power supply on a surge protector strip.
Have to turn off machine and surge protector because power supply still hot hours after turning printer off.
Also , I unplug the cord and replug to get blue light on power supply to come on.
Bed heats up so I know it is getting power.
Current issue: Having a heck of a time getting computer to see printer.
I have downloaded Arduino, Cura and Repetier, already used Pronterface.
I do not get the same options as the install video, Frame 40 .
https://www.youtube.com/watch?v=yj0R2RxSZcoPort com 3 available in Prontrface and Com 1 in Repetier
Previous 3D printer would connect right up so know how it should work.
This is what my Pronterface.exe.log says:
Traceback (most recent call last):
File "pronterface.py", line 1566, in connect
File "printcore.pyc", line 76, in connect
File "serial\serialwin32.pyc", line 30, in __init__
File "serial\serialutil.pyc", line 260, in __init__
File "serial\serialwin32.pyc", line 56, in open
serial.serialutil.SerialException: could not open port COM3: [Error 2] The system cannot find the file specified.
Also tried this tutorial: First 5 steps do not happen.
http://www.plasticscribbler.com/tutorial/getting-started/item/92-3d-printer-driver-installation-windows-7#.U9WWR7Gp6SrThis document helpful too:
https://onedrive.live.com/view.aspx?resid=3333905E3CA56169!197&ithint=file%2c.pdf&app=WordPdf&authkey=!AKzwTwccd-ajXHcAny ideas? Is it a driver? Firmware? Or should I pack it back up? still have box.
