Printer Connected but Not Responding
Postby Grieg Pedersen » 28 Dec 2014, 18:30
Since completing assembly, I have been struggling with inconsistent response from the device. When I use RepetierHost to try to talk to the printer, it does connect but printer type reports "Unknown" and no commands from Manual Control have ever received any response. All commands are still in a "waiting" state. The extruder position shows in red, meaning that it is unknown.
I fear that my main board is dead on arrival, but I'm way past the 7 days when IAP will replace it.
Anyone?
Grieg Pedersen
Re: Printer Connected but Not Responding
Postby Grieg Pedersen » 28 Dec 2014, 19:21
Never mind! I found garbage in the log, adjusted the baud rate, and have movement! Now I need to correct that Y axis limit switch!
Grieg Pedersen
Postby vinixtito » 05 Mar 2015, 14:28
I have the same problem. How did you find the good baud rate and what kind of garbage in the log? Also, where can I find the log file?
Thank you.
Best regards
Vitor
vinixtito
