Which usually Insulation Effect Is Great In Glass Greenhouse
Postby ahwhglass » 13 Dec 2018, 01:57
In the brand new conjoined greenhouses currently under construction, solar greenhouses, a glass greenhouses and plastic movie greenhouses are common structural types. Which two types associated with insulation chambers perform properly?
We all know that temperature is the basic condition for ensuring the standard growth of agricultural crops. Greenhouses are an insulated agricultural facility that creates a good environment for the typical growth and rapid development of agricultural crops. Insulation is usually an important task in the particular agricultural production of greenhouses. It is usually necessary to choose a suitable covering material.
In order to check on which kind of covering material has good temperature preservation, we chose two greenhouses near 35 degrees north latitude, and tested them at the end of March, which tend to be glass greenhouses and multi-span plastic-type film greenhouses. In this absence of artificial heat, the indoor temperature is usually measured every hour inside two greenhouses in numerous weather and recorded.
By our practice analysis, it is found the fact that plastic greenhouses are warming up every day, the nighttime temperature is usually obvious, and the nighttime insulation effect is just not obvious, while the glass greenhouses have got better insulation effects throughout the day and night than your plastic greenhouses. The thermal insulation performance on the tempered Laminated Glass greenhouse provides improvement over that of the nasty greenhouse.
The glass greenhouse is known for a beautiful and novel contour, good light transmission plus good heat preservation. Plastic-type greenhouses are economical and also practical, and the price is low. You can choose according to the requirements of production and properly.
Glorious Future is a China supplier of Greenhouse Insulated Tumbler. We have a high-tech work shop. We have a total quality management system. Pick Custom Laminated Glass Supplier, you can be find most careful and innovative service!
ahwhglass
